bob johnson
Thread starter- Joined
- Feb 25, 2009
- 4,306
I am wiring my new boat...I bought it as a tiller version, but am adding a center console i bought at the same time from the factory. I am going to buy a breaker panel. the center console came with three switches fused through their fuse panel....Ill use those three for running lights an anchor light and interior cabin lights...so they wont be on my breaker..
everything else I am going to run will go through a 6 postion waterproof breaker.
they sell them in 45 total amps and 100 total amps...
I will run two seperate wired bilge pumps( on seperate circuits)
I will run a depth finder
I will run a spot light
I will run a radio
I will run a circuit for a future live well
my question is how much should I set for the trip on each circuit.. the bilges I already have and were used
1000 gph each Rules
also I am running a power source for a hydraulic powered jack plate
and am running a few guages
like a water temp
a water pressure
a fuel pressure guage
a tach
an amp gage
should i supply each power source to my guages through the breaker ???
would the spot light and the bilges be the largest amp draws??
would a 20 am be sufficient for them??
I figure the radio wont need much
nor will the fish finder
the spot will be via a cigarette lighter type power recepticle ..so other things might get plugged in once in a while
I mlike the breaker so i dont have to crawl under the console and replace fuses
I figure if the breaker goes twice in short order...just leave it off...till I find the source..but otherwise it would be quick to bring it back up!!
thanks
sorry of the questions are a slight mundane....
thanks
bob
I will run a radio
1000 gph each Rules
like a water temp
a water pressure
a tach
an amp gage
thanks
thanks
bob
