1987 Mercruiser 170 coolant gaskets
mcook5
Hello,
I have a coolant leak and was told to replace to gaskets for the pump inlet and the impeller cover. I have the Clymer shop manual, but it is hard to follow. Does anyone know of somewhere I can look up instructions for replacing these coolant gaskets? video? or better instructions?
I also may be doing something I shouldn't be doing...With a coolant leak coming from these impellers, should I just be replacing the gaskets or is there something more? Any help, would be much appreciated, thanks!:confused:
droptheline
Re: 1987 Mercruiser 170 coolant gaskets
is the leak coming from the pump inlet? those 470's with their aluminum blocks and closed coolant systems can be a real nightmare if not properly maitenanced. Identify the leak with a pressure test and post back.
mcook5
It looks like it's coming from there, however after doing more research, it looks like it can be the cam seals? I bought this boat for close to nothing and I have limited maintanence ability, so I may have to just sell it. I'm at my whit's end.
