mercury 95 hp QUESTIONS??
its a merc 95 hp inline 6 made in 1967
1 do i have a thermastat?
2 where does the coolant water exit my engine,has no pee hole
3 what are the slotted openings for in the lower unit are they got intake of water also?
thank you,
doug
OldMercsRule
Re: mercury 95 hp QUESTIONS??
No
The older inlines "silver blocks" like yours have the exit for the tell tale low on the block, (edit: actually the exhaust cover). Later models, (black blocks) were in between #3 and #4 (half way up the tower), or at the top of the block. If the water line is still hooked up try compressed air to clear the passage.
Yes.
thank you,
doug
Your welcome. Good luck. JR
OldMercsRule
Just looked up your engine on usboatsupply, (they have the complete parts list and related drawings for yer 1967 950), the tell tale hooks up to the base of the exhaust cover, and you can see a picture of the rubber water hose and the part numbers for the fittings if you look at the drawing for the "bottom cowl and shift linkage".
I hope it is still hooked up and some cornpressed air clears the way so it show you a water stream. It prolly will not be fun to install this critical indicator if it is not on the engine as the quarters are a bit tight inside that lower pan.
i just went out and looked and i cant find a pee line or even a fitting on the block where it would hook up
beside the pee hole where else does the water come out?
what are the clear hoses on the side of the engine block for? they hook to brass fittings?
thax again
OldMercsRule
It would not be easy to see as the rubber hose hooks to the base of the exhaust cover very low in the motor pan, (cowl). See the usboatsupply online catalog drawings.
The rear of the mid section.
Someone may have replaced the fuel lines with clear lines. If so I would make sure they are approved fuel lines, (prolly not).
You have two fuel pumps and a fuel line loop to feed the three carbs. The factory lines were black rubber, but alcohol is real tough on 'em.
I have replaced most of the lines on me old silver blocks with modern fuel lines and 5/16 brass barbs. There are also return lines from the main bearings on the block for oiling, (factory lines were black rubber).
thax again
Glad to help. JR
Ill Take Some Pictures Tommorow Yea I Have The Black Fuel Lines To
These Are Clear Ones That Start At Bottem Of Block And Go Up To Middle Of The Block Then Up To The Top Where It Ends
OldMercsRule
Sounds like the oil return lines for the main bearings.
