oil draining from pee hole
bhuggins
i have a 1993 johnson 25hp that was given to me. i got it running but then after i cut it off it dripped oil/water mixture out of the top pee hole in the lower unit. i took the lower unit apart, put new gaskets on the water pump and put it back together. fired it up and again after i cut it off it drips water/oil mixture that turns to just oil after a few minutes. any ideas?
rolmops
Re: oil draining from pee hole
The top "pee" hole in the lower unit is a drain from the exhaust housing and it is quite normal that it drains water and some unburned fuel.In fact it is a sign that the hole is not plugged up.
dannyman3
just fixed that prob on mine if that is oil comming from the bottom hole on the foot it was the seals under the pump plate on mine there was two seals on it the was called upper driveshaft seals mine leaked the foot oil out that little hole evertime put the water to it i have a 1990 200gt not sure if same on yours put that is where i would check if i was you as those seals fixed mine
dannyman3
i looked up your motor the part number is 0332261 you will need two of them they are under the water pump plate called upper driveshaft seals that will fix you up you can go two shop.evinrude.com and look at it put you motor info in and pull your info good luck
Vic.S
If the oil is black and gungy then it is most probably just partly burnt oil from the fuel and is normal. If it is clean and obviously gear oil then It is leaking from the gear case, most probably as dannyman3 says leaking from the drive shaft seals below the water pump. The seals are #23 in THIS DIAGRAM
Check the gear case oil for signs of water ingress.
Read THIS ITEM from the Engine FAQs board
bhuggins
it is draining from the top hole in the lower unit. so i am hoping like ya'll said that it is just some unburnt oil from the fuel. it is black and i have drained the lower unit once and it was not cloudy like it was mixed with water. thanks!
EARLS BOAT
if the lower unit does not have any water in the oil i'd say you are good to go!
F_R
Just another case of oil coming out the drain holes. Absolutely normal and the question comes up every day.
One more time: Every drop of the oil that you put in the gas (or oil tank) goes through the engine. Some of it burns (smoke) and the rest goes out the exhaust. When you shut it off, all the water and exhaust residue drains out. Those drain holes ensure that none of it stays in there to freeze or corrode.
