Leaking oil around prop
woppert
I have a late model Johnson 15 horse. As I brought my motor out of storage I noticed a small amount of oil leaking out of the space between the prop and the lower unit housing. Any ideas? I didn't drop the lower unit oil last fall and was planning to do it this spring. Oil is black with no grit or anything in it. Thanks for the help.
lindy46
Re: Leaking oil around prop
Could just be unburnt gas/oil mix which is normal. Does it smell like gas?
F_R
That is the exhaust pipe. You put oil in the gas. Every last drop of that oil goes through the engine, with the gas. Some of it burns (smoke) and the rest goes out the exhaust. As it goes through the exhaust system, it picks up particles of carbon, making it black. Then it drips out and gives the owner something to worry about.
Check your gearcase oil (you should anyway), and if it is ok, relax.
kenmyfam
Agree, most likely exhaust sludge.
Mas
Most likely (99%) it is 2-stroke oil as mentioned...just monitor your LU lube oil on a regular basis & you'll be fine!
MAS
