ken_23434
Thread starter- Joined
- Jul 28, 2008
- 313
I am reading up on what I need to do for replacing my bellows on my 88 Alpha 1.
It seems the service manual is written for completely taking apart everything in the outdrive. I know I do not need to do everything listed in there. (Wish it had a step by step just for doing the bellows).
Another write up I found said to remove the small clamp from the shift cable bellows and that is all it said.
I am guessing I need to cut the lock wire and remove the set screw from the shift slide to separate the cable from that piece. Then remove the small clamp from the shift bellows.
After that, the cable would just slip through the shift bellows?
I am guessing on all that. Not really sure. I do not want to take apart more than I need to.
