familyfun
- Joined
- Feb 4, 2009
- 43
I have a 1988 125 force on a 1988 bayliner 1800 cobra that I just bought this year. I am still in the learning process of outboard motors or well boats in general. I got it out on the lake a few weeks ago and could only run with the cover off, I put the cover on and it would die. If I got the boat idleing along I could put the cover on and it would run WOT, pull into neutral it would idle for a few minutes, try to go and as soon as the gears would engage it would die. Cover off ran just fine no issues. I was told maybe exhaust was filling up in the cover and chokeing out the carbs from either the bellow going out to the pee holes or up from the l/u. I pulled the l/u and replaced the impeller, seal in the housing and the seal on the water tube going into the housing. Put a grommet with some sealant were the water tube comes down into the l/u. Put it in a tote and it ran fine, no problems with cover on and cover off. Took it to the lake and i'm back to square one. Cover off runs okay as soon as we put the cover on it died. Plus, even with the cover off I really had to give it the throttle when engageing the gears or it would die. So, new impeller, new seals and gaskets in l/u, plugs have about 4 hours on them, fuel filter cleaned, and fresh gas. Why won't it run with the cover on? Where does the engine get it's fresh air from? If I push the throttle all the way forward (leaving it in neutral) should the carbs be wide open? Right now if I push it forward the carb linkage don't engage until about 3/4 of the way WOT then in only moves a very little. I know this is alot just trying to get it going before memorial day weekend.
Thanks in advance,
Josh
Thanks in advance,
Josh
