I know this will a little long, but I will try not to be a try to be thorough. I took my tank out cleaned it and put it back in last weekend and when I went to try and start the motor it would just barely crank (batteries fully charged) and after I few tries I seen that my negative cable coming from my engine to the #1 battery was smoking. I went and bought new 4 ga marine wire for the postive cables I ran and 6 ga for the negative side and I made sure I had good connections on the new ends, liquid electrical tape and the heat shrink around all. Now I cant get my motor to even crank over. I have 93 115hp Johnson and I did the test with my test light and I have power to the soleniod, power to the yellow/red wire on the soleniod with key on and power to bottom wire to starter with key on which leads normally to a bad starter. I just by chance had a spare starter and put it on and still the same thing. Any help or thoughts would be highly appreciated. Sorry its so long.
