imported_TheMan
Thread starter- Joined
- Oct 19, 2006
- 224
Well gentlemen, I finally got around to putting my acquired parts together onto the boat.
Took it out for a test drive on Thursday. Hit 48 mph right off the bat, which is pretty good given what I've been at before (tops ~42 with 2 barrel).
After running a while I checked the oil and it was rather milky. Didn't have the problem before i swapped and the only changes were the heads, intake, and carb.
Given those options, I suspected the intake was the problem. I didn't give this much thought when doing it, but I torqued the manifold to the 11 ft.lbs specified per the Edelbrock 2114 installation procedures. After I found the water in the oil I went back and looked at my original torque for the old manifold. It used to be 40 ft.lbs on 12 bolts.. now i have 11 ft.lbs on 8 bolts.
I suspect this is my problem and it didn't seal the water jackets, but do you have any thoughts? Does anyone that did this upgrade remember what torque they used?
Thanks for any input.
