ssanders14
Thread starter- Joined
- May 4, 2009
- 10
So on Saturday I had a tournament and our spot was about 10 miles from the launch site. We run wot for about 9 miles and the motor starts acting like it is getting caught in some hydrilla or weeds so I start bring the throttle back and the engine has stalled. When I try to start it it won't even turn over. I check the prop and there isn't anything on the prop and no damage to the prop. I thought the battery was dead. We fish for about 10 minutes and I try to start the motor again and barely turns over like the battery is dead. Wait about 45minutes and try to start the motor again and it starts but sounds really bad. So I shut it down. Start it a little later and run it on a low idle for about 5 minutes and it dies. I shut it down for the rest of the day and get a tow back to the ramp. When I get it home I put it on the muffs and it starts fine then about a minutes later it dies and the prop is turning a little in neutral. With the motor off it seems a little harder than it used to be to turn in neutral. When I get the motor in Forward and turn the prop it turns about a 1/4 turn then I feel some tension and then it clicks and turns about another 1/4 turn then clicks again. When in reverse it doesn't do this. Are my LU gears all messed up.
If this is difficult to understand let me know if you need me to clarify anything.
