bigredinohio
- Joined
- Jun 18, 2009
- 604
Re: 1973 wellcraft 165 sport airslot project w/ pics
Let me preface my reply by admitting that I am a complete novice to the boat building/re-building hobby. However, I have done a lot of reading on the subject, and I have a boat that I plan to eventually re-build, and I have a basic understanding of fiberglass techniques and boat construction. With that said:
I say forget the foam. I know the USCG requires it on smaller boats (under 21ft, someone correct me?), but are they going to tear up your deck to inspect it? If, heaven forbid, your boat ever capsizes or sinks, yes the foam will serve to keep your boat at the surface (so one would assume), but if that ever happens, the boat will be waterlogged and nearly a write off anyway. Also, if the worst should ever happen, there would be no foam mess to centend with should you decide to put the boat back in service after a disaster. The only possible advantage that I would consider is the sound insulation it may provide. But the same insulation could be provided by sound-mat merely glued to the top of the underside of the deck boards, well away from the actual bottom of the hull, where any water might collect (not on yours, though!) I personally wouldn't contaminate your outstanding construction with it, though.
I have yet to see ANY type of foam available to average schmoes like us be completely water resistant. It all retains some degree of moisture.
You asked, so there's my $.02.
-Tommy
I like to use Dynamat products. They make several different types, and I believe one of them is foam-free! Actually, I think it's made of rubber sheet. You might also do a search for Audimute products. The stuff they make is for construction to sound deaden interior walls and such. Dynamat is expensive, from what I remember. I'm not sure about the audimute stuff, though.
I have yet to see ANY type of foam that doesn't absorb, or trap, some moisture. Foam, even closed-cell, contains voids that if not coated, will provide hiding spots for H2O. There are some foam derivatives, used in the aerospace industry, that contain additives that 'coat' the cells and fill the voids within the foam. But they are both very expensive and unavailable to people like us. Anywhere ambient air can travel will contain moisure in vapor form. As temp. and pressure changes, water will condense out of the air and collect. The fewer places for it to hide, the better. I say, if you must put flotation in your new boat, put it under the cap or in the bow where any damage caused by moisture will be minimal.
Sorry I did not posts pics last night, my wife has the camera at work showing her friends pictures of her positive pregnancy testI did get two sections of the deck underside glassed in last night.
Congrats
That's great news!
Yeah it was pretty cool getting that glass work done!![]()
Yeah, I thought I remembered the Dynamat being fairly expensive. I only used a small amount in a trunk once to keep people from hearing the screaming........I mean, uhh, to keep the road noise to a minimum. It's actually nice stuff, it really made a difference in the car I put it in. Some race car guys use it for heat dissipation (think header collectors under the floor right where your feet are), which is kind of neat also. I actually like the sound the hull makes as it glides through the water though, especially when we are tied up in a cove with a slight chop lapping up on it. Kind of romantic, sometime puts the wifey in the mood.......
How's your back doing? I'll be in the same boat (no pun intended) when it comes time to start on mine, just wondering how you are coping.
Congrats on the news, kids are awesome! I have three, and not one of the lousy little so and so's will help me on the boat!! Just kidding, they're great, and they all love boating.
THanks for the congrats on the baby. We have tried for 8 years
Congrats
That's great news!
