ThePerchik
Thread starter- Joined
- Mar 27, 2008
- 36
Hi,
I have a practically new Karavan trailer. I have a 4 pin connection on my highlander. Last time towing home I noticed that the right side turn signal was not working on the trailer. Hitting the brakes would light up the box and would change the brightness when the head lights were on. So it looked like one coil on the two coil bulb may have gone to crap or something.
I came home and unscrewed the light from the trailer, opened it up. There are two bulbs in there. A small bulb that has two coils. And a very small bulb that seems to slide in. The pulled out the bulb with two coils. I tested it and one coil would not light. I popped in a new bulb and now both back lights on both sides will not illuminate under and conditions. The two orange lights at the front of the trailer are still working.
I put on of those small LED testers into the plug on my car and all works fine. After reading the forum i figured it is most certainly a grounding issues. BUT, the trailer is not wired to groud and each light has a ground wire going directly into the light.
Does anyone have any ideas?
