Catfishmaster1
Thread starter- Joined
- May 4, 2009
- 7
I got a 1983 70hp Johnson That i just bought...carbs, are all good and clean pump water a1.....
my problem is it starts right up push the key for the fuel primer crank it and its running runs at a idea just fine rpm up real high no problem....now time to take it off the trailer i shift it in to gear and it will start to die if i push the key in it take right off.... after run if it idel to long it wasnts to die just push the key in and it good to go.....
will take all advice....
