battery charger
roger777
I am looking for a bettery charger I can use while offshore. The only chargers I see are the kind that plug in the wall. Are there any that can run off a 12 volt battery and charge that same battery.. I carry a third battery when offshore but when night fishing with the family I run. livewell,cockpit lights,cabin lights, tv and dvd for the kids, mini fan for the wife,swordlight,radio, bilge kicking on and off, ect... Just want some peace of mind. Would hate to get stuck with the family..
thanks
Re: battery charger
Sorry but perpetual motion hasn't been invented yet. A battery is like a bucket of water. Once it's empty it can only be refilled from another bucket (or hose). You can charge one battery from another using jumper cables, but you cannot charge the same discharged battery with some magical device. Only a generator can do that off shore. Why not wire all of your batteries into the charging system on the boat. With the use of a battery switch you can select which battery you want to use to power accessories thus leaving the start battery off-line so you won't discharge it. This topic has been discussed to death on this and other forums so do a search on "Battery Switches" or "dual battery systems". We know you have three batteries but the principle is the same.
roger777
Re: battery charger
I am not looking for a magical device. I am looking for a battery charger that can be used froma 12 volt source rather thaen a plug in type.Not necessesarily charging off a dead battery.. Maybe a battery charger powered by a cigarette lighter or something. I just want to keep my batteries fully charged. I am going to be in the keys for 3 days and we will be camping on an island with no power. I dont want to lug around a generator.I do have dual perko switches. I guess i could run the motor for a while but I was looking for another way to charge them(quieter and gas sufficient).. The boat is going to be the only power source which we will be using alot.Another thing, I do have a pull cord for my motor. Has anyone had to pull start a 150hp? Just wondering how difficult it would be.
Thanks
boat1010
Re: battery charger
I don't think you are grasping what Silvertip is saying. No matter what you "power" the battery charger from that is 12 volts is something that you have on your boat. So why not just use the battery that you were going to drain to use the charger. Hook all three to the boat generator so when you are running the boat you would be charging all three batteries. Then you can select which one you want to run stuff off of. But what you want to do can only be done by running a generator or using the boat charging system.
Chiliando
Re: battery charger
Why not take a marine battery booster? I have the two batteries on a dual switch but I always take a fully charged booster. In your case it would start the engine. I would so as the others have stated and attach the third battery to your other two. With 3 batteries and a booster you should be good to go.
roger777
Re: battery charger
I understand what silvertip is saying. I dont plan on running the boat for long periods of time(to charge batteries). i dont know how long you need to run the boat to put a good charge on the batteries. I know that I can designate switches for certain batteries. Maybe I am overreacting thinking I am going to drain the batteries quicker then they will drain but I would rather take precaution. If it was only myself I probably would not even be posting.. I would just like to know if there is a way to charge batteries without having to run motors or without plugging a charger into a wall.. I guess that would have been a simpler question.
Thanks
captharv
Re: battery charger
Solar panel and charging regulator. To get about 10 amps, the cost is about what Honda 1000 cost.
Not trying to be a wise a**, but your question has no answer.
I am an electronic engineer by trade..
Answer to the other question. Dependant of what size alternator and battery usage, could take as much as 4 hours to recharge to 80%.
Just where are you boat camping?
I have a 24' cruiser. My ships batteries are 6 volt, 220AH golf cart batteries. 220 amp hours will run my fridge, TV, lights, etc for almost 3 days without starting the engine. However, we also usually run air at night, so I use a Honda 2000.
Runs the air, battery charger, and fridge all night on a gallon and a half of fuel.
scipper77
Re: battery charger
I would recommend a spare battery. And make sure the spare is fully charged before you leave for your trip. You could also bring one of those portable power packs for jump starting cars, If you need to use it however you are going to have to bite the bullet and let the boats charging system recharge the battery.
slasmith1
Re: battery charger
The answer to your question is a very simple no.
roger777
Re: battery charger
I think I am going to pickup a booster.. I have one my wife picked up a year ago on clearance somewhere. It wont even jump my kids big wheels. I have to pickup a good one..
thanks
roger777
Re: battery charger
I am going to be headed to the middle keys not sure which one yet(got any suggestions).. I wasn't sure about how fast the batteries will drain. I usually only run a few things for 6-10 hours at a time without a problem but I know I will run alot more than usual. Judging by what you run on 6volts I am sure I will be fine..
Thanks
reelfishin
Re: battery charger
If your going to be traveling a distance, and taking a chance of running all your batteries dead, you may just simply want to isolate the main battery, maybe even add a second or third deep cycle and not drain the main battery at all.
Then for redundancy, carry the power pack jump starter. I'd buy a good one, something commercial if you really need to depend on it.
A few small solar panels will also help, even the cheap one's you buy at Harbor Freight will help maintain your batteries or jump pack.
Other than that, get a small portable generator but even a small generator won't give you the high amperage boost a good power pack will.
I have a few of those $20 solar panels from HF which I place on the dash in the sun to maintain my boat when docked, they do prevent the batteries from going dead during the week when I'm not around, and do add some life to my deep cycle batteries while I'm out fishing during the day.
Re: battery charger
Let me try this one more time. When you ask to recharge a battery from a 12 volt source like a cigarette lighter, where do you think that 12 volts comes from? It comes from another battery and that battery is not an inexhaustable source of electricity. So all you are accomplishing is sucking 12 volts from one battery, draining it, and putting it into another battery. So you still end up with the same amount of engergy only swapping it between batteries. The end result is you still have one dead battery.
Joseph10
Re: battery charger
Actually, what you will end up with if you hook a dead battery to a charged battery is 2 batteries with a near equal engery content (i.e. both battery's will now be only half charged). And since the terminal voltage of the charged battery will be nowhere near the voltage output of an alternator, this will likely take many hours to accomplish.
Re: battery charger
I have seen these battery chargers for sale on Ebay. Pretty handy. The same folks also sell fuel separator filters that change the water in your fuel into a burnable mixture. Something to check out!
Jeep Man
Re: battery charger
You said you didn't want to lug a generator around. I don't think your giving modern generators an even shake. Honda(and other name brands) make wonderful, small, light units that are extremely quiet. I was on a job site recently and was having a conversation with another contractor. We were standing very close to a Honda 3000. I thought it was off, but in fact was rumnning the entire time.
Rickairmedic
Re: battery charger
I have a couple of the HF $20.00 solar chargers I kep on vehicles that dont get used daily just to keep the batteries up and they work great for that use. I would grab a couple of them to use on your ( spare ) batteries and keep one on the main battery as well but not use the main battery for anything other than running the boat motor while out.
Rick
H20Rat
Re: battery charger
i've been next to the smallest honda EU series generator and didn't even know it was running, i was literally 2 feet away! they are pricey, but if you want a very quiet generator, they are probably tops
