Re: 1988 70hp starter problem
Intermittent electrical problems can be the most difficult to track down. Cold, everything 'seems' to check out OK.
Start checking voltage drop while cranking the motor.
Pull the lanyard safety switch so the motor won't start.
Check voltage at the battery while cranking.
Again at the positive cable connection to the starter relay.
Again on the starter side of the relay.
Lastly, on the starter itself.
A remote starter button attached to the relay is handy, and only crank for a few seconds, just long enough to get a stable voltage reading.
If there is a poor connection you should see a drop iin voltage at on point in the path.
There is always the possibility that the starter bushings are dry, tightening up and dragging while heated from operating the engine, yet appears to turn fine when cold.
