mike64
- Joined
- Apr 10, 2008
- 1,042
At the end of last season I found water in the LU oil when I replaced it. So I just picked up replacement seals and a new impeller. Now I've reviewed the procedure on dropping the LU in the OEM service manual and in some posts here, and I reviewed some good advice on pressure testing in one of my posts from last year:
http://forums.iboats.com/showthread.php?t=273386
I'm kind of leery about removing the LU so I wanted to ask you guys with similar motors what advice/stuff to watch out for from their own experiences.
What I understand so far: It looks like after I drain the LU oil, I disconnect the shift cable from the powerhead, and remove several bolts that hold the LU on. Then I remove the LU being careful with the shift cable and a plastic guide tube that's in there.
It looks from the manual that the impeller is easy to get to, and I have an o-ring that I believe goes on top of the LU where it meets the midsection of the motor. That looks easy too. But I have 2 metal-backed rubber seals that apparently go on the prop shaft and drive shaft. Are those hard to get to? How much am I going to have to take apart?
Will I need any special tools?
Any tips on making the job easier? I read where a guy tied fishing line on his shift cable to fish it back up through the works when he put the LU back on.
