jwbergeron
Thread starter- Joined
- Aug 25, 2003
- 47
My starboard motor cuts out intermittently. When the motor runs, it runs fine....but once in a while it will cut out like a key is turned off, eventually it will start again. When it cuts out, the high pressure fuel pump doesn't run at the turn of the key. But if I let it sit, eventually I'll turn the key, hear it run, and it will start right up. I've swapped complete vsts from one motor to the other and continue to have the same problem, so I'm pretty sure the fuel pump is fine...somewhere along the line, somethings not telling the fuel system to run.
I would greatly appreciate any thoughts or suggestions anyone might have to help troubleshoot this thing. Thanks guys
