TDD_Shizzy
- Joined
- Apr 19, 2009
- 3
Hey all,
I just started to tear down and restore my first boat. (going to start a restoration thread this weekend) The old wiring in the boat was awful, and it had zero accessories. (early 1980's 15ft fiberglass fishing boat). Well we want to do a little more with it then just a single battery to start the motor. I have a little wiring experience, but i dont know a whole lot about circuits and have never wired a boat. After scouring the forums and the net i came up with this wiring diagram, do you think it looks okay?
The blue squares on the image are just toggle switches.
There will be two batteries, one for starting and one for accessories. There will be a relay between the two, many have said the Borg Warner R3098 is good if i can find one (anyone suggest a newer version?). The accessory battery will feed a 6 circuit fuse block (probably blade fuses) and that fuse block will feed all my accessories as well as be the ground bus for them.
Does this look like i am on the right track? I am open for suggestions if anyone thinks there would be a better way to set this up. thanks for any advice!
