maineiac5586
- Joined
- Feb 14, 2009
- 770
so, i have a 76 merc 500 and have been chasing a bog. I had a slight bog when hitting the throttle that i couldn't remove by adjusting the idle mixture screws. . I adjusted floats and reinstalled carbs, bog still there. all of this testing has been done with motor running on muffs. what i have been doing is standing back at the motor and revving it up by swiveling the plastic bar connecting the two carbs together. this is the piece that swivels between the carbs to open the throttle plates. i still had the bog when i swiveled this link. for some reason i decided to try to rev throttle from the control in the boat. motor revved right up with only a slight blip when hitting the throttle. what i can conclude is that by using the throttle in the boat i am also adjusting the timing when revving. just wondering if this makes sense to anyone? should engine rev right up with no bog when swiveling the throttle link connecting the 2 carbs?? thanks
