tysonnathan
Thread starter- Joined
- Jun 2, 2008
- 246
1974 Johnson Seahorse, 15hp:
This motor was given to me and it ran very poorly when I got it. I have done some work on it over the past year or so and it is running ok, but I have a skipping issue that I haven't been able to get straitened out.
I had some other issues as well but got them pretty well fixed.
Parts I have replaced:
spark plugs
ignition coils
tune up kit:condensors and points
fuel pump
cleaned and rebuilt carb
The motor is runnng a lot better, but it is still skipping at times. The skipping seems to get worse the longer I run the motor. Almost always cranks on the first pull or two. Runs well for a while, but eventually starts skipping at slow speeds. Doesn't want to idle. Really skips bad at low to mid throttle when the boat is kind of plowing. The skips start and stop every few seconds sometimes. When I am accelerating from a stop, it will start to skip at mid to low throttle, but if I just hold the throttle there, it will often start running on both cylinders and take off. I don't know what else to replace on the ignition system. Any ideas?
spark plugs
ignition coils
fuel pump
