1988 dt85 leaving a light film on water
waffles1
I have a 1988 85 that i have noticed when it is shutoff there seems to be a light film coming from the motor on the water. I detect no gas leaks nor smell any gas fumes. Is this just normal exhaust residue on the water. Thanks
David Greer
Re: 1988 dt85 leaving a light film on water
could be small leak in trim/tilt
cousinabe
a torn fuel pump diaphragm can produce this... do you see the film while the motor is running or only when you shut it down?
waffles1
I only noticed it when the engine was off but I didn't really pay much attention while it was running while on the water. The engine always starts right up and runs ok. i would think if it was leaking from the fuel pump it would hesitate at least a little or die when i first start it up. I've run it quite a bit with the cowling off and have not noticed anything unusual or drips while it was running or even after it was shut off. It does have a miss when I get to about 4000 rpms but I haven't cleaned the carbs since last summer and it sat all winter so I am leaning to a carb problem there. Thanks for your reply.
Mas
Could be that you're running too rich.
MAS
waffles1
Thanks all for your replies. While I was cleaning the carbs I discovered my oil line slipped down just a bit on the barb and has a slight leak that was so minor it went undetected but was enough that it would build up overtime on the bottom and drip slowly out into the water. Thanks, again.
waffles1
I found that my jet on the lower carb was only out about 1 turn. The carbs looked pretty good so I am leaning that's where my miss came from. has anyone had problems with the jets turning themselves while running? The spring feels tight and the jet wasn't free. Thanks.
waffles1
I have one more question. I have a fast/low setting on my unit just below the cowling on the front. I have a manual but haven't checked this out yet. What does this actually do and how do you know where the setting should be?
Thanks
wood2turn
Waffles...
That Fast/Slow switch is a setting that will increase or decrease your idle speed. I'm pretty sure it also changes the richness of the fuel/oil mix but on that part I'm not too sure.
I found this out by changing the setting to get mine to idle so I could do more troubleshooting.
Terry B.
