Blue1983boat
- Joined
- May 6, 2009
- 16
Hey Everyone,
I finally decided to register for this website/forum after referencing it for the last 3 months. I purchased a 1983 Blue Fin 16ft Pro Fish with a 35 horse Evinrude and a newer bow mounted trolling motor in March and I've been redoing the interior. This forum has helped alot with my project and I've seen pretty good success so far. I'll try to post some pictures soon, but I'm pretty busy with work and school as well as trying to finish the boat up. I'll give a quick summary of what I've done so far..
That's how far I've gotten so far. I have epoxy and pour in foam that I will be doing in the near future that I bought from US composites. I also will be adding a inboard charger and a hummingbird 797. It's kept me really busy and I've been working a lot of hours trying to pay for it. Right now I'm trying to make new hatches that are flush. I'm using aluminum U-channel and ss hinges, but I'm having some issues with the hinges going into the side of the plywood. If any of you have made your own I could use some ideas. I think I figured out how to support the lid so you can walk on it, but the hinge is still giving me trouble. Like I said I'll post some pictures to clarify. Thanks again to this forum for all the helpful threads!!!
- Cleaned out all the trash
- Drilled out all the rivets in the floor and pulled out the old floor and casting decks, as well as the aluminum structural components.
- Pulled off the console and all the wiring.
- Cut of the factory poured in foam
- Cleaned the hull
- Found some old lures
- Removed motor and trolling motor
- Took out batteries
- Block sanded the interior hull and all the components
- Wax and greese remover on all components
- Rolled and tipped Rustomleum White Marine Primer
- Rolled and tipped 3 coats of Navy Rustoleum Marine Paint (Upper Interior Hull)
- Rolled and tipped 3 coats of Gray Rustomleum Marine Paint (Lower Interior Hull)
- Cut new plywood for floors and casting deck (1/2in exterior plywood)
- Cut new gray cabelas marine carpet and test fitted it with wood in hull
- Pulled out transom board and will be replacing with new one (Raising motor 2 inches)
- New wiring for the complete boat including a new DC distribution panel
