Gary H NC
Thread starter- Joined
- Dec 1, 2005
- 8,972
We have an older Carrier unit with the AC and gas pack.Model#48SS-024060321
I had the compressor serviced and its ice cold. 46* at the vents in the house.
The problem is the blower fan runs very slow.
I took everything apart,cleaned all the coils,replaced the seals between the return side and exhaust side of the fan compartment.That stopped a leak around the top of the outside unit that was blowing cold air outside.
I cleaned the cage fan.It turns very easy and the bearings in the motor feel smooth but it runs very slow.
The unit only cycles like it should at night when it cools the house off.
If i could get the fan speed higher i am sure the system would be fine.
Can barely feel it blow out the vents.
I went under the house in sealed all ductwork with mastic,all collars and joints are now sealed air tight.
I found one huge leak in the return side that is now fixed.
A new cage fan is 600 to 800 bucks!
Is there anyway to speed this one up? I don't think the fan motor is bad its just not running at full speed.
A neighbor AC guy said there is different connections on the circuit board for fan speed..
He never has time to come look at it..
