Hi all,
First I could mention that I'm new at this forum, which I found when searching solutions for my overheating problem. Great site!
My problem is that when I run my 1988 Evinrude 90hp VRO at low or medium rpm's everything is fine, but when I go WOT the overheating alarm goes off.
So I searched the site and found three possible causes: 1) bad water pump, 2) malfunctioning thermostats, and 3) swollen/misplaced water deflectors.
I have checked the water pump and it is fine. This weekend I'm planning to check the thermostats, and if that does not help, I'll go for the water deflectors. Good plan?
But my question really ends up at the third statement, regarding the water deflectors. From what I understand the deflectors are rubber hoses of outer dimension 3/8".
My question is: Are the hoses connected to cranccase and the heads? Are there water passing in the hoses?
Or is it only a "thing" inside the water channels in the cylinders to prevent the water to pass in between the cylinders? Would any other "thing" with the same outer dimensions do the same trick? Perhaps a material that do not get swollen with age or when overheated?
Thanks in advance
/ Magnus from Sweden
Thanks in advance
