My 'Newbee question of the day'
Span 24
Ummmm, what is this? :confused:
Thanx in advance!
Michael​
mphy98
Re: My 'Newbee question of the day'
looks like the sacreficial anode to me
JB
Trim tab to compensate for torque steer.
Action
Both guys above are correct! I noticed that on my alpha Gen II outdrive that anode is flat!
crazy charlie
Dual function.Sacraficial zinc annode and helps keep boat going straight to counter act prop torque by tweaking it the same direction that the bOAT PULLS WHILE UNDER WAY.Charlie
Jeff-in-PA
So if your boat steers "straight", mark where the fin is BEFORE you loosen it up to replace it when it starts to pit.
bhammer
Ensign
That's becasue you have power steering and the OP does not. Yours is just an anode!
Ike-110722
Nope, that's a gronicle for sure.
Ayuh,...
It's a combination Torque Tab/ Sacrificial zinc Anode,....;)
drewmitch44
i thought it was the muffler bearing
Splat
I think it's a Piston return spring.......
Bill
Span 24
Thanx to all who provided quality answers! I think that it is clear that the component in question is a combination zinc anode and a trim tab.
And to those who provided comic relief (even if the 'muffler-bearing' answer is older than outdrives), thank you too! :)
Michael
scoutabout
My I/O had power steering AND a nice pointy tab like that. :p
bhammer
Ensign
I have ran across some that do but most of them have been on older boats. I don;t think thye came as original thoug. Yours may have.
Partime
My boat was missing it when I bought it, so I installed one. I understand the "trim tab" purpose of it, but can someone explain the "sacreficial anode" purpose?
Thanks
Tacklewasher
Thanks
It will get eaten away by electrolysis before anything else on the boat. Really important if you run in salt. Without it your outdrive starts to get pitted and serious damage can occurr.
Partime
Thanks for the info. I don't run in saltwater, but still need it for the trim purpose.
