thomas.seay
- Joined
- May 9, 2009
- 12
I have a 1999 MerCruiser 3.0L and when I connected the water hose to it this morning for my test start before going to the lake, I noticed that I had water pouring out of the block behind the alternator. I found a small round (about 1.5" diameter) plug at the bottom of the bilge. I found the hole where the water is coming from and it appears that this plug goes there. I need to find out how I should put this plug back into the opening. What, if anything, should should I use to adhere the plug back into the hole. It's a tight fit, so I could use a rubber mallet to get it back in. Any suggestions?
Thanks,
Thanks,
