coolguy147
- Joined
- Jul 14, 2008
- 2,817
ok this guy wants me to fix up his outboard for him. now ive only worked on evinrude johnson's with the single carbs. this one has three
ok so this guy had fuel problems because his fuel were all clogged with junk so he put in a new filter new fuel lines on the outside of the motor.
now he wants me to rebuild all three of his carbs. im kinda hesitant cause i never worked on any of these motors. so how do i do it? he said that he will order a new rebuild kit for it. i looked at it and kinda simply except the oil lines might get in the way.
guys have any advice on takeing the things apart im kinda worried about the throttle linkage?
well rebuild the carbs r a bit different form my motor. does htis motor have a fixed high speed jet? and does the low speed needle need to be moved to clean the carb? and is the carb almost the same as a old evinrude?
the vro? does it inject oil into the carbs or is it multi point? what lines do i need to disconnect from the carb? oil? fuel?
