198- something 50hp Evinrude
BDUBBS1960
Does any one know what may cause a electronic ignition 50hp evinrude to start and run well,but not shut off by either key or kill switch ,only way to shut it down is to choke it thanks bdubbs
Bob_VT
Re: 198- something 50hp Evinrude
Welcome to iboats.
Something is wrong, something is not connected properly. I would suggest getting the specific manual and check out your wires. It might be something simple (since most kill switches are)...... but... you need the diagram.
A manual is available for sale here on iboats. :)
follow the black wire with yellow chaser, that is the kill wire, usually loose connection, or bad ignition switch.
