force single exhaust
kthkollar
Hello. I am wondering exactly what single exhaust means for a force motor. I am trying to find a prop and i am assuming it means the exhaust is through the prop and would require holes through the prop. The motor I have has an exhaust above the prop. Thanks for any help.
rabeck5792
Re: force single exhaust
if exhaust only comes out from under anti-ventilation plate,it is single exhaust.if it comes out from there & thru the prop,it is dual exhaust.normally it is called thru hub exhaust.
john from md
Michigan propeller has a direct replacement for Force engines. Look them up on the web and then give them a call.
John
