Cavaliermike
- Joined
- Feb 8, 2009
- 2
Hi,
I'm a newbie here. Just boat an 89 boat with a 470 in it. Filled it with gas and it ran beautifully for about 2 hours...then died...it restarted with difficulity, but would only turn about 1000rpm and mainly die when the prop engaged...barely limped back to the dock...oil pressure showed about 80 or so, temp 120-160...all fluids look good...are there things I should try and do or just call the mechanic...the plug wires, coil and the distributor appear pretty used...could there be a fuel contamination problem?
Thanks for any and all help...
cavaliermike
cavaliermike
