1964 LARK 40 HP replaced impeller
chask53979
i replaced the impeller and it doesn't pump water out the top ,i hook a hose to the lines going up the leg and the water doesn't come out the exhaust relief i let it run for awile and only just a little mist came out can you tell me what i did wrong before i change it a little water came out wile it was running
thank's for any help:confused:
Re: 1964 LARK 40 HP replaced impeller
pull tstat, and flush.
chask53979
pull tstat, and flush could you tell me what the tstat is as i am new to this
thank you
lindy46
Thermostat - it is in the top of the powerhead. Remove the housing held on by 3 bolts - it's inside.
chask53979
thank you that what it was a block in the tube
charlie
