..... The two port type is used in V engines
MUST BE AN EARLIER ELECTRIC SHIFT INTERMEDIATE HOUSING THAN I HAVE EXPERIENCE WITH. MINE IS A '75 VARIETY V-8 AND ONLY HAS THE ONE OUTLET ON THE TOP REAR OF THE IH HOUSING (see manual) and is supposeed to route water from the trunion fittings on the out drive to hoses on the engine/manifold.
SO WHAT YOU ARE SAYING IS THAT WATER PASSES THRU EACH TRUNION CAP AND WAS MEANT TO FEED EACH SIDE OF THE V MANI'S?On mine, when water is poured in it comes out the exhaust out... and when the engine is run exhaust gases come out the said ports.
This confirms what i saw months ago when i inspected the IH internally... That there is a tear/hole in the internal structure.
IS THIS FROM CORROSION? A SALT WATER UNIT? COULDN'T YOU HAVE IT WELDED? UP?
So, this means that any water coming up from the drive will not take desired route and travel under impeller presuure through the engine etc. It will take the easy route and run down through the tear and back out the exhaust out.
So, i will block the left trunion fitting so it passes no water.
I THINK THAT IS THE NORMAL PATTERN IN LATER ELECTRIC SHIFT INTERMEDIATE HOUSINGS. THE PORT TRUNION CAP DOES NOT PASS WATER IN MY UNIT. I will allow water to cool the drive as normal but use the flushing cap to take it away from the top of the drive and through the transom.
I will use a splitter to send it through both mani's and a combiner to bring it together and into the bottom of the engine.
It will then come back out the top of the engine T stat (unlike a marine engine, this engine has water flow like a car... in the bottom cold and out the top warm).
I will then pass the water into the failed Intermediate Housing to escape from the system and also cool the IH/ewxhaust area.
Job done.
The drive elements and impeller are fine
SO THE IMPELLER IS PUMPING UP A STORM? IT JUST WAS NOT GOING WHERE IT SHOULD? and i have cleaned these up and greased them.
I will put gear oil in the upper gear housing and close it all up for a fresh test.
