sick evinrude
tired evinrude
I used sea foam in the tank and carbs.idols fine give it throtle and pops and cracks falls on its nose help please.
Joe Reeves
Re: sick evinrude
Hp, year? Probably clogged, fouled carburetor(s).
film495
Re: sick evinrude
did it always do that or is it a new condition? set the high speed jet to the default and try it.
Joe Reeves
Re: sick evinrude
Still need to know what engine you're speaking of.
tired evinrude
Re: sick evinrude
1982 60hp 2cyl bought it new first time ever had trouble with it.
Joe Reeves
Re: sick evinrude
Your carburetors are fouled. Remove, dismantle, clean, and rebuild both of them. Be sure to manually clean the fixed high speed jets that are located in the bottom center of the float chambers.
tired evinrude
Re: sick evinrude
thanks joe carbs are clean as awhistle. now getting milky water out of the prop.are the prop seals bad. just put all new seals in the lower top unit.also is there a way to check the power pack and stator.
Joe Reeves
Re: sick evinrude
Have you checked for spark. If not, remove spark plugs, then check to see if spark will jump a 7/16" gap on all cylinders. Does it?
tired evinrude
Re: sick evinrude
finnally test run runs good then lets up. found that the fuel line ball does not stay very hard seems like you have to squeeze it a lot.
tired evinrude
Re: sick evinrude
well fixed all the wrong things i could find still falling on its nose. found that the squeeze ball wont stay firm is that a fuel line or fuel pump problem.
Joe Reeves
Re: sick evinrude
Fuel primer bulbs are normally installed so that they lay flat (horizontal) when running. The normal function is that the fuel level will drop to the halfway point which is normal. It will stay full and hard only if installed in a vertical position with the outlet facing up.
If squeezing the fuel pump, acting as a manual fuel pump, cures the problem, then the trouble is with the fuel pump (whichever type you have).
Spark..... With the s/plugs removed, the spark at cranking speed should jump a 7/16" gap with a strong blue lightning like flame.... a real SNAP! Does it?
