marineman16
Thread starter- Joined
- May 22, 2007
- 37
My trolling motor quit working. It is a 3-pin motorguide brute that is hooked up to a run/charge switch. To start, the motor DOES work when wired directly to the battery in 12v. No fuses are blowing (or blown). I replaced the run/charge switch and tested it. everything looks perfect so far.
The fun part: I am getting power to the back side of the plug, in 12v in charge and 24v in run, just as it should be. I can pickup the same voltage in the front side of the plug, where I plug in the motor. Somehow, it still will not run. Does anyone have anything else I can try? Could there be a ground or something I am missing? I don't get how I can run wires from a better directly to the motor and it work, yet it won't work when I plug it in, though I get the same voltage using either approach.
Help is much appreciated!
