I'm in the process of setting up the Mystery Boat (http://forums.iboats.com/showthread.php?t=307360) and I'm wondering about motor height.
Motor is a 1961 Johnson Seahorse 40hp (RDS-23).
I know generally you'd like to have the AV plate about even with keel.
I know with many older motors you need to run them deeper so they can adequately pick up water.
I know the current motor position (as low as possible) puts the AV plate about 2"-3" BELOW the keel.
I know there is only room on the transom to raise the motor maybe 1.5", and that much would be dodgy because the clamps would be right on the upper edge of the transom. Also note that this motor transom clamp is the two hand screws only - no way to actually bolt it to the transom.
Any thoughts? Leave it where it is?
aborgman
aborgman
