I've had pretty good luck with this motor until last weekend. I used it with no problems for five days in February, then winterized it. Took it out last weekend, and it started OK (a little harder than usual to begin with), and ran OK. Ran it at high speed, idle, stopped it and re-started a number of times for a couple of hours and everything seemed fine. Then while idling thru a fairly long no-wake zone it started to run rough and eventually died. I was never able to restart it. I tried taking the carb apart and blowing most of a can of carb cleaner thru it, and replacing the plugs. I know it is getting gas to the carb, and I know it is getting spark to both cylinders. I have a service manual and a Clymer's manual, but I'm not really sure where to start. Any sage advice? Not-so sage advice? Smart aleck remarks?
Thanks,
Lewis
Thanks,
Lewis
