wil7483
Thread starter- Joined
- Jan 19, 2007
- 377
OK, I need your help. I'm not a mechanic and I don't fully understand the workings of the internal combustion engine but I am mechanically inclined so I'll try anything once. I went out today to try to adjust my rocker arms to rid the engine of what I thought was lifter noise. After I completed it and got the engine all back together I was able to see a bit of an improvement but the noise isn't totally gone yet. However the engine is running smoother than it was before the adjustments.
Anyway, I then removed the carbs flame arrestor and watched the carb as I gave the engine gas. I never went over 2000 rpms but I did notice that the throttle plates weren't open fully. Or at least what I think are the throttle plates. Also, the choke has a crack in it so is that something that NEEDS to be replaced for optimum performance? I am still trying to get the engine to turn at 4200-4600 rpm's with the 19p prop. The best I can get with the 19p is 4050. With the 17p I get 4300, and with a 15p I am able to get 4600 easily but top speed is only in the 35mph range.
When I turned the engine off and placed the remote control in the WOT position I still do not see the throttle plates opening. Maybe I'm looking at the wrong thing so please help me out on this. Thanks in advance guys.
Here is a video of the engine running. I haven't gotten the idle right yet so that is why it sounds like that. Right now it is idling at about 550 rpm's. I would like to get it to idle at 700 rpm's.
