I have a 74 johnson 6hp can not get it tocrank,ihave replacedthepoints,condensers,coil,newplugs&wires.ialso did acompressiontest on it is 65on both cyld.rebuild carb to.i am get gas to the bottomplug,but not the topplug.any help thxs
Have you verified good(blue) Spark?
Does your pump ball get hard when pumped and stay that way?
Have you tried spraying a little pre-mix into the carb to start it?
I just got my 6hp running last week.
Carb was dirty, trash blocking main jet
Points were way to tight.
Once these 2 things were corrected and the fuel pump confirmed ok, it fired right up.
