Home Cookin'
- Joined
- May 26, 2009
- 9,715
Re: Opinions on which boat to buy.
I know about your waters.
You want a fiberglass center or dual console with an outboard. No option. No aluminum unless it's a jon boat; no I/O. Look for a self-bailing cockpit.
From there, size is personal but 17-19 is a good range for a solo or a couple of friends, also easy to launch/retrieve. Good for cruising; just put in the removable cushions.
flat bottom gets you to the specks and pups in the marshes, but it will beat you up running across the bays. a modified V is a good compromise--look at Key West (I use a 17' Key West DC and a 19' Carolina Skiff CC in waters like yours). you want to be able to pole around the flats, whether fishnig or stuck, and you can't do that with some lead sled deep V high side Bayliner and a stern drive.
The reason there are so many bowriders for sale is that people will hang on to their CC's, or they sell fast or before being listed, by word of mouth. I bet for the bowriders for sale, like searaybayliners, the owners either quit boating or went to cc's or cabins.
You can run a smaller motor as the boat gets lighter. My 19' scoots with a 50 b/c there's nothing to it. If it were a proline or similar, I'd have a 115. Just a trade off; the more finished the boat the more weight the larger motor required.
Consider a T top for fishing (you can always add one) but if you are alone you can work around a bimini.
