maddog2
Thread starter- Joined
- Apr 24, 2009
- 94
I just spent $2,700. on a "remanufactured" long block Mercruiser 4.3LX V-6.
(1992) model. Apparently the intake was leaking and water mixed into the oil. I just drained 6 quarts of warm "Milk" from the oil pan.
It was on the water for about 15 minutes while going through the listed break in procedure from the mercruiser manual. I stopped in the lake, turned off the engine and restarted...then a loud pop. The engine started backfiring through the carb and was running rough. I got her back to shore and took her back to the mechanic.
We removed the intake and found that the last pushrod on the right hand side was loose and I believe the rocker arm may have broke.
The intake looked fine, it was removed from the old engine, cleaned in a professional parts washer and gaskets material was removed from the intake mating surfaces.
I was told by the mechanic to take it to a machine shop to pressure test for cracks or leaks....
Is there any other way that water may have entered the oil?, especially since the rocker arm and pushrod issue.
any input would be greatly appreciated.
James in NC
High Rock Lake-----
James in NC
High Rock Lake-----
