Bought a new prop - wrong one?
dthrckt
I've just tried to install a prop I purchased for a 1986 Johnson 2hp model JCOCDR.
The prop I purchased does not match the original prop and does not match the diagram provided by the retailer.
The original prop has a recess for the prop clutch ring and prop hub. It also has a hole through the cone of the prop, perpendicular to the codder pin hole and parallel to the shaft.
The prop I received has a plastic structure (similar to the spokes on a wheel) where the prop clutch ring and prop hub should reside. It also lacks the hole through the cone.
I have attached a photo and the gearcase diagram from the retailer's webpage. On the left is the original prop and the prop I received is on the right (original was broken when I bought the motor). Clearly, the prop clutch ring and prop hub cannot be inserted into the new prop.
Can I use it anyway? I can't imagine why the designer included those parts if I can just leave them out! Also, what is the hole in the cone of the original prop for - to equalize pressure?
dthrckt
Re: Bought a new prop - wrong one?
Just talked with the retailer and then with BRP. It seems that the prop is the only one available.
I assume...the clutch ring and prop hub were originally meant to absorb (some) underwater impact, and that the replacement prop forgoes this to keep the cost low.
I'm still wondering what the hole in the original prop cone is for, but since this is the only prop I can buy (new) I guess I'll have to use it...
