How to treat plywood?
chicubs08
I just replaced a piece of plywood by the ski locker. I used regular plywood, not marine grade. How do i treat it and make it water proof? Thanks
a1nowell
Re: How to treat plywood?
I redecked my pontoon boat this past year and could not aford marine plywood. I bought 3/4" BCX plywood, the X means exterior glue. I coated it with Waterguard, manufactured by Olympic, I bought it from Lowe's.
valor_7
epoxy resin is supposed to be the best as far a durability and strength but cost is high, around $80 for a gallon. Polyester resin is half the cost. I'll be putting in my floor next weekend and I plan on coating the top, sides and botton with thinned polyester resin. Thinned so it can seap into cracks.
danond
It doesn't need to be thinned; if anything, thickening it will provide better protection and sealing.
Mark42
...... I'll be putting in my floor next weekend and I plan on coating the top, sides and botton with thinned polyester resin. Thinned so it can seap into cracks.
Its a good idea to protect the wood, but remember that thinning resin generally results in a weaker resin after cure. Thinned resin will seep into cracks better than straight resin, but as far as soaking into the wood, thinned and straight soak in about the same, although there may be more creep of the thinner agent, which will buy you nothing.
If you use a thinned coat, don't thin more than 20%, and follow with a straight coat. Also the best plan is to include some CSM or cloth in the coating, because straight resin (especially polyester) tends to crack easier when there is no glass to give it strength. Glass in resin is like rebar in concrete.
When glassing the recessed deck pieces installed in my Capri, I didn't bother to glass the edges, it was just too much trouble to try to glass 5/8" wide edge. But it doesn't appear that the edge will be a problem especially seeing how much resin gets sucked in the end grain plies.
Mark42
A good example is the home built wood canoes that have a coating of resin and glass to protect the wood. They typically use a 8oz cloth with resin so the resin is a little tougher and can handle banging and scrapes better. Same works for the deck of the boat.
ondarvr
Most paint or stain type coatings do little to protect the wood, polyester alone is of almost no value because it will soon begin to crack, epoxy lasts longer but will still fail, the time line depends on the wood and epoxy used.
Add glass to either type of resin and the protection can last for many years, you still need to do a good job though.
seven up
Further down the list after epoxy and polyester in water resistance is shellac. If is still avialable.
Bob_VT
or spar varnish with multiple coats sanded between each coat....
halas
Please !!!no shellac!!!
tmcalavy
And open all doors for the plywood, too...otherwise dinner and a movie and fresh flowers will get you nowhere.
jpmurphy
Did we chase him off ?? Hope not. :eek:
Yacht Dr.
Hello cubs..
Yes .. how to waterproof your ply after install ? that is your question right ?
you already skipped ahead.. too far ahead..
wet all dry areas of ply with 20 % thinned resin/acetone .. dont let cure.. repeat when ply stops soaking.. apply full resin ( without wax adds ) when tacky but not fully cured.
YD.
