1stpriority
Thread starter- Joined
- May 18, 2009
- 15
I am replacing the 4 transom brass drain tubes and was thinking of using pvc pipe instead. Any suggestions would be appreciated.
DRAIN- ONE -WAY SAFETY PLUG
Patented one way safety plug lets water out of your bilge but not back in! Ideal for every boater who has ever forgotten to put in the plug. 1/2 NPT. Features our exclusive plug handle which allows the plug to be tightened and loosened with a wrench, screwdriver or even a nail!
P/N: 50032270
UPC: 737765322701
When I re did my transom I had to replace three of them, the white plastic ones that were in there were total garbage the sun ate them to nothing in the splashwell...... .
Danond....your spot on m8...
4. In my sailing days I can tell you one thing.. IF I can take a hammer and knock off a through hull fitting.. forget about wet transom..were now talking SINKING ! DO NOT REPLACE WITH NYLON OR PLASTIC !
This is the issue with the brass tubes. They leak when they fail - and you won't know it because your transom is absorbing the water.
I just not realized this is exactly what ruined my transom! It was completely rotted out right around the transom, and about halfway to the top of the transom.
You say they leak when they fail....how exactly do they fail? I have the brass one pictured (not a one way though) with the 3 screws. It appears to me that it was sealed by coating it with silicone. It wasn't broken or anything. Still appeared to be in good shape.
I'm wondering if I should replace it with something different this time? I don't want a plastic one, I'll either go with brass or steel.
Would you mind explaining, in layman's terms, how to PROPERLY replace the drain tube so it wont leak? I'm NEW to boat building and fiberglassing. I am replacing the deck and transom on my bayliner outboard. I don't want it to leak.
Thanks for sharing your knowledge!
When I re did my transom I had to replace three of them, the white plastic ones that were in there were total garbage the sun ate them to nothing in the splashwell. The brass one in the bilge was perfect 20+ years later. So I decided to go back with all brass they were cheap, easy to put in and looked great when finished. I'm not in salt water so corosion isn't as much of an issue. I didn't use a flair tool they dont work all that well so I made my own method of install and flair it was easy and only took about 30 minutes to do all three, plus they were an off the shelf item at a local boat store. PM me if you want more info on how to install easy.
Hello 4runner..
If you really dont want water to leak ( into your core ) then replace approx 1" around the fitting with fiberglass.
ON THE INSIDE, hole saw the wood out. DO NOT cut into the outer fiberglass lams. Pack with resin-chop mat-cabosil peanut butter like mohair filler ( you make this on your own ). Only fill about 3/8" at a time so you dont over heat the packing. keep filling after each has time to start cooling off. After filled, grind around repair and layup a layer or 2 of mat and woving ( or biax etc .. good 18 oz glass ).
Drill your hole for fitting from outside..sand your fitting and gelcoat for prep. clean with acetone goop the crap outa it with 3m 5200 and bed down .
Of coarse dry fit and predrill your fitting before you clean and bed
Good luck ... YD
