rs2k
- Joined
- Aug 2, 2008
- 486
I'm getting ready to try and fire up (again) an OMC 260 HP Chevy 350, but there are a few things that bother me about it. This engine has a brother on the starboard side that I was able to get running long enough to find out the carb needed to be rebuilt. I have a slight suspicion that the port engine may have a cracked block, but so far the evidence is not conclusive.
The first time I tried to fire up both engines I found that they weren't getting fuel. As a precursor to purchasing the boat we tried to use starting fluid. Both engine cranked over with no problem, the starboard engine sounded nice and even when cranking while the port had an obvious exhaust leak sound and feel to it. The oil in both engines looked great, but the port engine was showing it had way too much oil which lead me too believe there may be water underneath the oil.
When the engines fired up on the starting fluid, the starboard engine seem to run fine for about 3 seconds. The port engine on the other hand backfired and caught the carb on fire a couple times. When the port engine finally did run it, was obvious that it had a loud exhaust leak and was backfiring.
When I brought the boat home, I was able to restore fuel flow to the starboard engine and got it running and idling right away without a touch of starting fluid. The port engine's carb however, was leaking too much to start it.
There are no external cracks large enough to be seen in or around the port engine. All spark plugs also appear to be installed and intact. Both intakes had a little rust directly under where the carbs sat, but both engines are in far better visual shape then my 1971 OMC 305 on my other boat. The inside of the intake and valve covers looked freshly rebuilt.
Does anyone have any idea what might be wrong with the port engine? Could an out of adjustment distributor cause backfiring and loud exhaust noise? How about a stuck valve? What about a rusty piston or stuck ring? Any ideas would be greatly appreciated.
Thanks!
Thanks!
