kevinclark93
Thread starter- Joined
- May 11, 2009
- 42
Okay I have a couple of post trying get help on this, but now I have a little more information. I have a 95 150XL offshore mercury outboard serial OG397... The overtheat alarm constant beeeeeep is going off even with a cool engine even when the engine is not on.
I have ohm checked the temp sensor and it is GOOD. I have check the wire for a short and it is GOOD.
The temp sensor has a tan/blue wire running to a post. The oil module also has a tan blue wire running to the same post. Then from the post another tan/blue wire runs to the main connector out of the engine.
So if I remove just the temp senor wire from the post the beeeep continues, but if I remove the tan/blue wire coming from the oil module with the temp senor wire removed or not removed the beeeeep stops. The oil module tan/blue wire is going to ground and completing the circuit for some reason tripping the horn.
What I find interesting is that if I remove the oil module wire and then ground the temp senor wire the alarm sounds beeeeep, so I have no idea why the oil module is on the same post as the temp senor. Since the temp sensor works with out it.
Please help... Also the wiring diagram is not 100% correct in the book I have, where can I find one for the specific engine model and date I have. I think I have a Solec book
