shift bellows plastic bushing
humpbackshooter
is the plastic bushing on the shift cable that goes to the out drive at the trasom important? it came out when i reinstalled the cable. how does one place it back when i can not see where the cable goes into the trasom? alpha one,gen II 4.3 v-6 the manual does not talk about this.
thanks, phil
jam1ej20
Re: shift bellows plastic bushing
The bushing protects the shift cable from abrasion and scarring. It goes in the transom housing where the cable goes through. I?d try to put it back if I could. Premature cable degradation will ensue.
jam1ej20
To replace the bushing all you have to do is remove the cable from the linkages on the motor and run the bushing down the cable. It pushes into the transom plate and snaps into the hole the cable goes through. It's a tight fit, but that's how it clips in. It's a tight place to work if the motor isn't out so good luck!
