Engine is a Model J150STL CEM
It was serviced (tune up and lower unit) run once or twice then has setup for several years, part of the time under a car port and part of the time outside. Going through the Waking a Sleeping Outboard thread (good info in there). I however have come across several things that I want some advice or info about.
In testing the primer bulb I noticed when I got the bulb stiff some fuel was dripping out of the silencer and pooling under a little metal plate mounted under the carbs. Is this normal behavior? The Engine was tilted up at this point. I have always noticed a lot of grime buildup around there and had never figured out why.
My other question at the moment. I intend to pull the lower unit and replace the impeller just in case texas heat may have made that formerly new impeller that was sitting brittle, and as a learning experience. I'm trying to make sure the bolt I intend to remove is actually the right one for releasing the shift shaft. The Clymer manual just kind of points to a dark recess so I tried to take some pictures of what I think is the bolt for confirmation. They call it a screw but it looks like a bolt to me.
What I "think" is the bolt I need to remove is circled in white here
A little zoomed out and hidden from the flash in the dark recesses here
