we wrote the other day about this problem but there has been no change.....we get nothing when we turn the key but when we place the key in the run postion and pull the cord it starts right up....we cn turn it off with the key so there must be some life left in that ignition switch......one thing we forgot to mention was that there is a green wire that is not connected to anything in the motor running along the lfet side as you look at the motor from the rear......it has a male connector at the end but we cannot find where it may have plugged in.....we take the wire and make a sweep of the area that it would reach but see no female connector or place to put the wire in the motor........oh the ground is connected from the batery to the motor also..........
