Yon'der Horizon
Thread starter- Joined
- May 21, 2009
- 29
Top of the mornin' fellow boaters! Well, I've read thousands of articles on this forum, yet this is my first post. I've been able to work off other posts in my troubleshooting thanks to the wealth of knowledge shared here. So thanks in advance to all contributors!
Important details are in bold (may help to skim read
Just bought a used boat 'bout two weeks ago. (1989) Stratos 289FS with(1989) 200 XP Evinrude. Motor started right up, but had a few hiccups at idle and midrange. WOT is smooth. Installed new plugs, cleaned 2 (out of 6) carbs as one was overflowing due to a varnish ball under the needle seat. Pulled the second just to compare. Didn't pull the other 4 carbs since they visually looked good. This, along with a slight idle adjustment and the motor has been running pretty good, aside from the occasional fart.
So two days ago, upon our first holeshot, while accelerating, the Tach Guage went kapooy. Toast. Motor ran fine until we went to land 'er on the trailer, then absolutely would not start. Back home, test start fired right up. Bypassed Voltage Regulator, hooking up Gray Tach Send Wire to Yellow/Gray Stator Wire. No change on Tach Guage. Assuming Guage is bad. I believe I read an article stating someone had a similar problem, no Tach and a bad VRO was the problem. However, a guy at the boat landing yesterday stated the VRO is purely mechanical and shouldn't affect the No Start condition.
I am leaning towards a flooding motor, because it starts, usually, after it sits for 10 minutes, whether hot or cold. Plugs are a bit wet, bulb firm, fuel filter full, little leakage out Carb area when the motor is tilted up. Seems to struggle to start most when in the water, compared to in the driveway with no load. I plan to dig into all the Carbs today to check the floats and needle seats. Before I do, I thought I would check to see if there is anything else I should be focusing on, like the VRO. I plan to set timing with a Link n Sync to fine tune the rough idle, but of course have to get the motor back up and running again.
My apologies for the long post, but sometimes the details are part of the story! Thanks very much in advance for any wisdom you can shed on this situation!
