johnson model no.?
SYCHOWAND
hi im trying to identify the exact model and year of my johnson 90 v4 twin but i cant seem to find a model number anywhere! have been told its on the shaft but cant see a thing! the boat its on is a 1991 model and would imagine the engine is about the same age. the only number i can see is under the cowling on an oval plate on the engine block which is R8616146 any ideas?
kenmyfam
Re: johnson model no.?
Look on the port side of the transom bracket and post what you find.
domwebhost
If you take the cowl off and look down at the top of the engine, see if there is a round, shiny nickel/quarter sized plate, if it is there, you should be able to cross reference the Jxxxxxxxx and come up with the model #, I think.
kenmyfam
Correct as well.
SYCHOWAND
hi thanks for replys i hav an R8616146 number in an oval plate on top of the engine also inside the oval is a small sqare with an M stamped in it is this what you mean if so how do i cross refernce it? cheers and sorry if i sound dumb
kenmyfam
Should start with a J90xxxxxx
Did you find the plate on the transom bracket ??
tx1961whaler
I think that the "R" prefix means it is a factory rebuilt (or replacement) powerhead.
ezeke
That is probably a replacement powerhead number. Try posting some photographs of the cover and engine, etc, someone will probably be able to ID it for you.
The welch plug should be round, convex, nickel-sized, but not oval.
SYCHOWAND
ok thanks i will take some pics next weekend and post them on monday cheers
SYCHOWAND
Look forward to seeing them
hi yes found the plate on transom braket was painted over but paint scraped off ok the model No is BJ90TLESB and the serial No is the same as the one i described on top of the power head R08616146 so if anyone knows the year of my engine and the best workshop manual to buy id be very grateful cheers!!!
Bob_VT
it's a 1990 model.
SYCHOWAND
SYCHOWAND
